Odor coming from Eclipse
Home Forums Products Rackmount Odor coming from Eclipse
    • #115133
      JNB
        I just picked up a new Eclipse and after about an hour of operation I noticed an odor coming out of the vent on top that smells like something is getting hot.  It’s not a strong odor and I didn’t notice any smoke.  The unit appears to be functioning fine and I didn’t detect any hot spots on the case.  I suspect it’s a power component that normally runs hot that is just burning-in.  Should I pull the cover to inspect or is this to be expected?
        Thanks,
        Nick
      • #150896
          Mysterious smells are not expected.
          But, given that the unit should be under warranty, I suggest that you not worry unless you see other problems.
          In the unlikely event that it were to get hot, you should send it in.
