Orville 100% Wet
Home › Forums › Products › Rackmount › Orville 100% Wet
    • #201006
      ReidarNikolai
        Hi there
        How can I globally kill dry signal on the effects in the Orville?
        Thanks in advance
      • #201638
          Hi, sorry I don’t have an Orville to dig into this further for you but it looks like this is detailed on page 54 of the user guide here: https://cdn.eventideaudio.com/uploads/2021/07/OrvilleManual.pdf
        • #201647
          ReidarNikolai
            Thanks for answering. I have been on that page a couple of times – and also in the machine itself. The Wet/Dry parameter is actually backwards – when 100% it is fully summed – at 0% it is only dry signal going through. Very opposite 🙂
            Anyways – searching around WWW is not that easy – AI says you can route your way – but I have yet to discover how I can do that. AI says it is possible but I don´t know.
            I have used this in a guitar rig and I seem to remember that I had dry muted then – but needed a factory reset after a battery faulty.
