September 7, 2016 at 5:20 pm #113688
duantro
ParticipantHi I have an Orville unit that I’ve been running in via digital, and am needing to route it via my interface analog I/o. No matter what routing I use, I can’t seem to get any signal. Any ideas?
September 8, 2016 at 1:45 am #144323
ModeratorEventide StaffYou're not really giving me any information.
I would suggest that you re-initialize the unit – this should default it to analog in, analog out. If it still does not pass analog, it probably needs looking at.
September 12, 2016 at 11:06 pm #144359
duantro
Participantnickrose wrote:You’re not really giving me any information.
What additional info would help? I powered up with the 8 key help and selected the analog stereo in after a long hold on the program button.
Still no analog signal coming in. Reselected the wordclock in as clock source. Any ideas?
September 13, 2016 at 2:30 pm #144362
ModeratorEventide StaffSorry – sounds like it needs a service. Probably a power supply issue if none of the four analogs work. support@eventide.com
September 17, 2016 at 5:16 am #144408
duantro
Participantnickrose wrote:Sorry – sounds like it needs a service. Probably a power supply issue if none of the four analogs work. support@eventide.com
Do analog inputs show up under input menus or dsp?
September 17, 2016 at 12:46 pm #144410
ModeratorEventide StaffAnalog input gains show up on the LEVELS menus, and as routings under SETUP. See the UM for more info.
