November 19, 2018 at 11:23 pm #115068
I have an Orville in my home studio & am looking to incorporate it into my electric guitar rack setup with a large Midi floor switcher / controller .
I have no issues bypassing / muting or changing parameters via Midi on my Lexicon PCM 81’s as they are less complicated but the Orville is really confusing me . I’ve read the Midi section in the manual 3 times but just can’t make sense of it . I have no idea how to set the orville so that it will resond to my midi footswitcher.
Basically, I want to be able to Bypass/Mute either DSP A or DSP B via MIDI. At the bypass menu / bypass A setup I am unsure of what to select.
So far I have set Midi to Enabled in the Setup menu, my Base channel is set at 1 and I have the option to send Midi Control Commands (CC#) or Program Change (PC) commands from my ‘Custom Ausio Electronics’ Bradshaw style Midi floor controller.
I have pressed the Bypass button to enter the bypass menu, and held the ‘Bypass A’ soft key for 1 second to take me to the Bypass A setup menu . What should I select for ‘mode:’ ?? Midi Single ? Midi Double ?? Midi Program ??
I’m also unsure of what value / message # I would need to send to actualy perform the DSP mute as well!
Please Help! I’m surprised how complicated this is turning out to be .
November 30, 2018 at 5:37 pm #150722
I can maybe help you some of the way. Try this:
1. setup your midi controller to send a midi cc and as a toggle switch. The value useally is 127 for on and 0 for off.
2. go to the bypass A setup on the Orville and select Capture Midi
3. press the foot switch on the midi controller
4. select *done* in the bypass A setup
Hope this helps.
