Orville noise
Home Forums Products Rackmount Orville noise
    • #115102
      sofus@foppa.dk
      Hello dear Eventide
      My trusted Orville have started to behave a bit. There is a rather loud noise comming out from only output 1. It have the character of white noise and it changes in amplitude if i change the clock internally in the unit. Also when i change the clock some crackling occurs untill it stabilizes. The noise also changes character when changing the clock.
      Please let me know if you have any suggestions to how i could treat it. Also a service place in Denmark would be appreciated
      Thanks
      Sofus Forsberg
    • #150835
      Alas, this is a twenty year old product, so there is a limit to how much support we can offer.
      It does sound as though you have an A/D or D/A problem.
      Because of the age of the unit, you will have trouble finding a local service place. Your best bet is probably Sound Service in Dusseldorf (Germany), but even they may suggest you return it to the US.
      The Orville has detachable audio boards – maybe if you placed a deposit, we could send you one to see if it works.
      Before you do this, I would suggest that you (or a technologically competent person) try exchanging the two boards, and see if it makes a difference.
