August 10, 2009 at 3:57 am #106369
bryan r. tyler
MemberHi,
I was hoping someone could tell me the exact physical depth of the Eclipse from the rack ears back (not including cables). The website description says 10.5", the manual says 12.5", and while that's a small difference, it's enough to make the Eclipse either fit or not fit into my SKB PS-100 pedalboard's rack. Thanks a lot for the help.
August 10, 2009 at 7:58 am #118900
IDeangelis
MemberMy unit goes 10.9" (27.7 cm) from front to rear.
all the best
I
August 10, 2009 at 11:41 am #118903
bryan r. tyler
MemberThanks a lot for checking- that's not even one of the two dimensions I found listed 😀
August 10, 2009 at 12:01 pm #130012
IDeangelis
Memberwell…mine is an early prototype and might somewhow be "unique".
The 10,5" spec is what should probably be considered correct.
I
August 11, 2009 at 4:41 pm #130015
ModeratorEventide StaffWarning. Warning. The early prototypes had different dimensions. Alert. Alert.
August 11, 2009 at 4:58 pm #130016
bryan r. tyler
MemberSo is 10.5" from rail back the new "normal" size? 😀
August 11, 2009 at 5:36 pm #130017
achaput
ModeratorThe Eclipse chassis goes back about 10.5" from the rack ears, however the bnc connectors and any cables you connect will make at least 11.5" deep.
August 11, 2009 at 5:46 pm #130018
bryan r. tyler
MemberI only need to use right angle MIDI and 1/4", but it still may make it long enough not to fit. I may have to find an Eclipse user in southern CT that'll let me try to rack it. Thanks for the help guys.
