Problem on DSP7000
Home Forums Products Rackmount Problem on DSP7000
Viewing 3 reply threads
    • #115992
      nonolepiano
      Hello
      I have an issue with my DSP7000. On startup the is a message : ” Problems found during startup. See SETUP/info for details. Pressany key to continue”
      When i go to Setup/info, the message is : Problem in internal Ram Bad Checksum
      Coud you help me please ?
      Thank you
      Arnaud
    • #155286
      You should look at "Fixing Internal Memory Problems" on UM p.73. If you follow these instructions the message should go away.
      If it comes back again, you will need to change the internal battery – these only last about 10 years so it could well be overdue. Any technical person can do this.
    • #155301
      nonolepiano
      Thank you, it’s working.
      But… i’d like to save all my internal memory. I don’t have a pcmcia card, and i want to use bulk dumps.
      I read user manual on p.69, but impossible to transmit sysex… however i do that frequently with all my synths… 🙁
    • #155302
      nonolepiano
      Hey ! it’s working… pfff wrong cable
