Quirky H90 Tip – Autotune / Doubler
Home › Forums › Products › Stompboxes › Quirky H90 Tip – Autotune / Doubler
Viewing 0 reply threads
    • #166757
        Yes, I’m easily amused, but this is a parameter I’ve been asking about here for over a decade now:
        https://www.eventideaudio.com/forums/topic/tech-q-for-eventide-pitchfactor-scales-quantization/#post-107677
        The H90 Diatonic / QuadraVox algorithms now add a Quant toggle to the parameter set.  You can use it to transform any pitch bends into stepped glissandos, which are constrained to the current Key & Scale.  Here’s a rough & dirty starting point:
        • Mix – 90 (just a touch of Dry)
        • Pitch A / Pitch B Mix – A10+B10
        • Pitch A – Unison
        • Pitch B – Unison
        • Delay A –  10 mS
        • Delay B – 20 mS
        • Key – E (example)
        • Scale – Minor (example)
        • Feedback A – 0
        • Feedback B – 0
        • Quant – ON (essential)
        • In Gain –  gain-staging specific
        • Out Gain – gain-staging specific
        • Tails – system specific
        • Kill Dry – system specific
        Similar values for QuadraVox, noting the exposed parameter changes.
        Variations: select any Key or Scale; change one of the Pitch intervals to a harmonized note; drop the Delays to zero to remove the subtle doubling effect.  You can ease the main Mix back to 80-85 for some added detuning.  You will run the risk of some real Hoover bloopers with some bending techniques, and hear the processing lag.
