November 29, 2011 at 4:47 pm #108218
Hey Guys
I am trying to set up my EVE/NET Remote for H8000FW to send MIDI info and record parameter automation in Logic. i have read the UM about MIDI GROUPS and REMOTE CONTROLLING PARAMETERS and PLACEHOLDERS and REDIRECTION but i am just trying to put all the pieces together….below i have 3 inquiries:
1) if i want to use the EVE/NET as my external controller, the midi in out plugs on it are not fitting tightly….can i just connect midi in out on back of H8000?
2) In logic do i need to create an external midi track and record enable it then press record to capture automation? i would assume so as this is how i automate my virus C….the sysex data plays alonside the midi track and the audio is printed.
3) Let say as an example i wanted to assign the reverb DECAY parameter to be modulated via the large, main spin knob on the EVE NET…..is this possible? or should i just go MIDI CC route….i ried to assign decay to volume # 7 CC but was unsuccessful….. how would i go about accomplishing this?…..can you please explain step by step and simply….i have read the UM but i need laymens terms please. thank you
John
November 29, 2011 at 7:48 pm #122873
Audiotistic:
Yes.
Audiotistic:
Sorry – this is a question for Mr.Logic – beyond our product knowledge.
Audiotistic:
The wheel on the Eve/Net works the same way as the wheel on the H8000 front panel – it adjusts the currently selected parameter.
To use MIDI instead, look at "Automatically" Selecting a MIDI External Controller" on p.103 of the UM. This should tell you how do do it, but if there is anything specifically that you don't understand, please ask.
November 29, 2011 at 10:02 pm #122876
Thanks Nick for your help……so im thinking hit CAPTURE MIDI then move mod wheel (or whatever is external control) ad monitor horizontal bar to see if the control registers?
November 29, 2011 at 11:27 pm #134017
That's essentially it … there are further complexities if you want to change the scaling (the amount the value changes for a given MIDI value), but start with the MIDI capture.
