Routing utility 2.8 with H8000FW on lion 10.7.2?
Home Forums Products Rackmount Routing utility 2.8 with H8000FW on lion 10.7.2?
    • #108358
      Hi!
      I have recently switched to mac so there may be something lacking in my mac knowledge here but I can't get routing utility 2.8 working on my mac mini server 2011 running lion 10.7.2.
      I have everything else working ok with the H8000FW running 5.6B1 SW and matching mac driver.
      I can see the busy light blinking when I try to go on-line using either the Dice midi port or an external midi interface but it goes into off-line mode after a few blinks. "Cannot connect Going to local mode"
      I can get other midi messages working both ways with both Dice and my external interface so the problem isn't the midi connections/devices. Anyone got this working?
      Cheers,
      Per
    • #123077
      Ok. Reinstall of 5.6B1 on the machine made it work! Don't know what it really was since I checked installed version number and everything before. I was extra careful to make sure a clear setup was performed this time. Might have missed it the last time.
