routings for H8000fw
Home Forums Products Rackmount routings for H8000fw
Viewing 5 reply threads
    • #107208
      hi !
      I just received my H8000FW.
      how can I run 2 separate non-monolithic presets at the same time in both DSPs,the routing being set in parrallel A||B , via midi with one foot controller ?
      I can only obtain one DSP at once,when I'm sending with the foot controller the prg change number;I CANNOT OBTAIN  a same prg change number for both presets in the 2 different DSPs.
      Thanks
      E-M Pulinx
    • #120658
      achaput
        If you turn OMNI mode OFF and set the MIDI Base channel to 1, then MIDI program changes on MIDI Channel 1 will change presets on DSP A and MIDI program changes on MIDI Channel 2 will change presets on DSP B.
        So if your MIDI foot controller can send MIDI program changes on two different MIDI channels at once then you can do this.
        -Alan
      • #120684
        thanks Alan.I'll search such a foot controller !
        Now my last question :
        Many of the presets do not have wet/dry controls. The balance is in the system ,not in the preset. I have  for sure the dry sound that I can put in parallel with the effects, letting a 100%  wet setting , but  -to my ears- it doesn't sound the same!
        So,how to do for saving a wet/dry control for each preset ?
      • #131859
        ThreeFingersOfLove
          E.M Pulinx:
          Now my last question :So,how to do for saving a wet/dry control for each preset ?
          You need to modify the algorithm in VSig. Just insert a mixer and route the dry signal directly from the AD converters and the wet singal at the end of the FX. Also insert 2 knobs for the dry/wet amount and send these to a MENUPAGE module so that they appear in the actual H-8000FW LCD screen.
          Regards,
          Yannis
        • #131863
          unguitar
            Pulinx,
            as for a footcontroller I can suggest you to check http://www.gordius.be
          • #131876
            MANY THANKS TO ALL OF YOU
            EMP
