Saving A / B presets as one
Home Forums Products Rackmount Saving A / B presets as one
    • #114720
      tajnost
      Hi!
      I’m quite new to my Eventide H8000 and I’ve got a simple question: I make a lot of “patches” with a sampler on DSP A and reverb/pitch effects on DSP B. Is there a way to save them both as one “monolith” patch or just as a A/B “preset” to recall them together at once? Can’t find anything in the manual about it… maybe there are some ways to ‘overcome’?
      Thanks in advance!
    • #149129
      You should look at the second section of "Storing and Loading Setups" on UM p.138, beginning "There is one difference between saving a Setup and saving a Program. It is possible to choose whether, when the setup is reloaded, it will automatically load the programs that were loaded when it was saved."
      • #154620
        NikosGuitar
        nickrose wrote:
        You should look at the second section of “Storing and Loading Setups” on UM p.138, beginning “There is one difference between saving a Setup and saving a Program. It is possible to choose whether, when the setup is reloaded, it will automatically load the programs that were loaded when it was saved.”
        please forgive my question but i didn’t found it at the manual..
        is it possible to recall the setups via midi?
        Thank you!
    • #149144
      tajnost
      Exactly what I wanted to find. Thank you!
