Setting volume from one Algo to another in parallel in same FX Chain
Home › Forums › Products › Rackmount › Setting volume from one Algo to another in parallel in same FX Chain
    • #116371
      J20056
        Essentially I have an FX chain with delay and reverb, to be use as 100% wet. The signal path I want to create is GTR –> DLY –> RVB, or GTR–> DLY or GTR –> RVB.
        The last 2 are easy once I have the first as I can mute/bypass either.
        The question is how to control the amount of DLY sent to the RVB for the first case. I want the direct output of the DLY to be 100%, but I want to send the DLY to the RVB at say -15dB.
        The only way I can think of to make it work it so add a Thru module between the DLVY and the RVB and set the output gin of the Thru to -15bB (and ultimately map this to an expression pedal).
        This approach works fine, but I was wondering i there is an easier way given constraint that volume from the direct DLY to chain output needs to be at 100%?
        This is a picture of he chain I implemented and it works fine, although it seems a bit vain to use an algo slot for Thru just to control 2 volume connections.
      • #157307
        John Baylies
          The picture did not make it to the post, but I think I understand your issue.
          Given the constraint that volume from the direct DLY to chain output needs to be at 100, you will need a Thru algorithm to control the volume from the DLY to the RVB, unless you use one of the 4 to 8 channel delays that have volume controls for each channel, such as #516 "Eight Delays", in which case you could do something like this.
