shifting formants
Home › Forums › Products › Rackmount › shifting formants
Viewing 5 reply threads
    • #106259
      formants
         my question is: can I shift formants separately from pitchshifting with an Eventide 8000FW? (In the wayI can do it with Melodyne (http://www.celemony.com/cms/index.php?id=358) elastique (http://www.zplane.de/index.php?mact=News,cntnt01,detail,0&cntnt01articleid=31&cntnt01origid=39&cntnt01returnid=92)  I have to do it in real time. Tha's why the software doesn't work for me. Does someone know about it. I had a EventideDSP 4000and it couldn't do the job.
         Thans for help
        "Eventides Ultrashifter formant-maintaining pitch shifter optimized for the human voice."  Can I do it separately???!!! Or another machine?
      • #118691
         Hello
        it sounds a bit unclear to me what exactly you need to do.
        Normally you don't pitch shift formants; they happen to be the peculiar physical aspects a phonetic media overimposes on the sound it generates. When you pitch shift such sound, the formant_accurate pitch shifter should calculate the correct formant at different pitches so that the sound remains "loyal" to its character over the shift range, avoiding chipmunks artifacts.
        Could you explain what exactly is t he task you are looking into?
        thanks
        I
      • #118692
        formants
          In the
          software "Melodyne" and the "elastique" you have the option to shift
          pitch and to shift formans. Formants shifting in a – direction makes
          the sound more muffled if you add more formants the sound becomes more
          treble high quality. I do not how to explane it better. I totally
          understand your mentioned aspect:
          But for me the nice thing was to be able to play with the density of the sound.
          So if Eventide has calculation (with the Ultrashifter)I was hoping that
          there is a way to have the possibility to calculate those formants
          fluently….
          http://images.google.de/imgres?imgurl=http://www.musicmarketing.ca/products/images/melodyne_plugin2.jpg&imgrefurl=http://www.musicmarketing.ca/products/melodyne_plugin.asp&usg=__lfVox09K1AqxOYmMo9mz0zban2w=&h=362&w=600&sz=30&hl=de&start=11&um=1&tbnid=xo8H8TkDq3RSCM:&tbnh=81&tbnw=135&prev=/images%3Fq%3Dmelodyne%2Bl%2Bformant%26hl%3Dde%26client%3Dfirefox-a%26rls%3Dorg.mozilla:de:official%26sa%3DG%26um%3D1
          Thanks for trying to help
          Am Fri, 5 Jun 2009 12:40:00 -0400
           schreib IDeangelis <bounce-IDeangelis@eventide.com>:
          Hello
          thanks
          I —
          View this message online at: http://forum.eventide.com/cs/forums/p/5504/23376.aspx#23376
        • #129796
          UltraShifter is mostly a voice dedicated shifter. It allows both automatic calculation of correct formants in relation to pitch shifting and manual adjustments too.
          If you are trying to venture to more uncharted directions it may not be the proper tool for you. I can only advice you test the unit and check if it's useful to your needs.
          kind regards
          I
        • #118694
          formants
             thank you. It is kind tuff to see a gear in realtime…. I have to find a store and listen….
          • #118717
            richardt
              There are some presets in my Orville which allow formant shifting withour changing the pitch. I'm sure those presets are also in the 8000 but I can't remember which ones they are at the moment (1000+ presets to go through to find them).
