November 19, 2012 at 1:16 am #109294
I have a synth with a coaxial RCA phono output, which can have its format changed to send an AES signal instead of SPDIF. I want to connect the synth to my AES/EBU interface but don't know the correct impedance the cable should be. It would also be handy to know which pins are soldered to which wires. Help greatly appreciated.
November 19, 2012 at 4:27 pm #124013
I would just plug it in to the SP/DIF – should work OK.
November 19, 2012 at 10:54 pm #124016
The only way is a cable with RCA on one end and XLR on the other. The problem is I don't know for definite what impedance the cable needs to be.
November 19, 2012 at 11:18 pm #135018
AES is 110 ohms, SP/DIF usually about 75. Not critical unless the cable is long.
Connect pin 3 of the XLR to ground on the RCA, pin 2 to hot. Or the other way round – it will work either way.
November 22, 2012 at 3:16 pm #135020
Thanks. Is there a set impedance per metre guideline? At what length does the impedance become important? Or rather, is there a "x" metre = "x" ohm conversion rate?
November 22, 2012 at 6:12 pm #135021
I did transmission line theory at University, but it was a long time ago. Impedance for a cable is constant, and not affected by length.
The issue is more that problems caused by mismatches increase with longer cables.
I think you are worrying too much – do what you think is right, and worry about problems only when they occur. Example – AES specifies 110 ohms, but most people use mike cables – who knows what the impedance of a mike cable is ?
November 23, 2012 at 1:56 am #135022
Thanks for the reassurance
December 12, 2012 at 12:29 am #135068
Unfortunately, it didn't work. No audio full stop.
December 23, 2012 at 3:17 am #135098
Had the cable redone – got audio buried in digital clipping. Please, for the novice that I am, post a diagram stating which pins should be connected at both ends.
December 26, 2012 at 5:38 pm #135099
AES is symmetrical, meaning it can be connected either way. Try connecting pin 1 and 3 to ground, and pin 2 to hot.
December 27, 2012 at 5:46 pm #135100
I'll try that. Meanwhile, I connected SPDIF RCA from the EMU to the Eclipse, and the same problem occurs – its the clock of the EMU that's at fault.
