Tap Tempo using latching footswitch connected to pedal 1 jack
Home Forums Products Rackmount Tap Tempo using latching footswitch connected to pedal 1 jack
Viewing 6 reply threads
    • #106530
      How is tap tempo controlled via a footswitch to the back of the eclipse?  What kind of footswitch is recommended?  Is the tapping accurate using this method?
    • #119239
      *How is tap tempo controlled via a footswitch to the back of the eclipse?
      It's fine!
      *What kind of footswitch is recommended?
      An unlatch type would be fine
      *Is the tapping accurate using this method?
      More than accurate, if your foot is good with time!
      best
      I
    • #119240
      So any unlatching pedal via 1/4" to either pedal 1 or 2, and designate tempo source in the setup menu?  Also, I'm currently running 3.51.  All sounds good here?
      Is the footswitch method more accurate than MIDI CC method?
    • #130366
      Better using Pedal 2 as #1 is assigned to presets input levels by default.
      V4.0 is out!
      The fooswitch might be probably a little faster than MIDI.
      best
      I
    • #130370
        Italo is right – a directly connected switch will give better tap results than MIDI.
        A MIDI connection is always a little "rubbery", but will usually be OK if you have no alternative.
      • #130404
        You could use an unlatch switch pedal like a Boss FS-5U, but I would even recommend a Boss FS-6. It's a dual switch pedal, each can be latch or unlatch, and you can connect it with one stereo 1/4inch cable to for instance Pedal 2 of the Eclipse. Then, you can use one of the pedals  (tip 2) as tap tempo, and the other (ring 2) for another function, for instance PGM+ to switch to next preset.
        Jean-Francois.
      • #130405
        Here's another cool pedal I've run across:
        http://this1smyne.com/pedals.html   (E3)
        A lot of guys on The Gear Page seem to be using them with their TimeFactors. I've been meaning to order one for my Eclipse but haven't yet. I was imagining PGM+, PGM-, and Bypass but maybe tap temp makes more sense than Bypass… 😉
        af
        // no personal affiliation with this product – just one I've marked as interesting from others' comments
