I have an old amp that i use that only has an analog switch to change between the 2 channels, and it connects via a p10 cable. Is there a way to use pedal1 or pedal2 inputs or any other method on the Eclipse to switch between those 2 channels (without a separate midi switcher)?
Thank you
