November 7, 2011 at 4:34 pm #108165
ModeratorEventide StaffNormal
0false
false
falseMicrosoftInternetExplorer4
Eventide is happy to announce the availability of V5.6 beta software for registered users – look on the H8000 support pages.
This is essentially a maintenance release, adding support
for OSX "Lion" and fixing a number of bugs. If you are not troubled
by these bugs and do not use "Lion," you need not install this
update.Improvements
Show More...Show Less...1)
FireWire driver support for OSX 10.7 Lion™, in both 32
and 64 bit versions.2) Improved
driver control panel.Notes:
If using the H8000FW with a computer, the computer control
panel may offer a 192kHz sampling rate option – this is not supported by the
H8000FW and should not be used.Bugs Fixed:
The TT numbers are reference numbers for our internal bug
tracking database, and should be mentioned in any related support enquiries.1) TT940
Confusion between DSP bypass and wet/dry.If wet/dry is set to 100%, the effect it heard correctly. If
then bypassed using DSP bypass and it's bypassed correctly. (clean) If the
wet/dry is then adjusted with the effect bypassed it becomes un-bypassed. The
bypass lights still blink as though bypass is still engaged.2) TT963
In some presets you cannot reach the second UI page for the first hotkey.In some presets (notably 4208 and 4510 but likely others) the
parameter page under the first hotkey shows multiple pages, but does not let
you access them by repeatedly pressing that hotkey.3) TT964
ADAT routing problem on H8000 and H8000A with V5.5With H8000 and H8000A running V5.5, no audio was passed until
the routing was manually changed.4) TT989
Some presets cannot be savedIf presets 879 "Ambiclouds 2" or 880
"Vibropad" are saved as User presets, the saved presets cannot be
reloaded, giving a "Can't Explain" error.5) TT992
Menu page missing when preset is on DSP BWhen preset 1720 "Piano sostenudo" is loaded in
machine B, the 2nd page of the 2nd softkey (delays) cannot be accessed,
although it is visible when the same
preset is loaded in machine A.See also http://forum.eventide.com/cs/forums/p/6760/29678.aspx
http://forum.eventide.com/cs/forums/t/7289.aspx and
others.6) TT995
Preset 2120 is distorted.See http://forum.eventide.com/cs/forums/p/6760/29785.aspx
7) TT1120
Crash when turning wheel in "Particle Accelerator"Load 631 "Particle Accelerator". Hit [mtap]. Turn wheel. Crash !!!
8) TT1124
Crash when remoting levelsHit [LEVELS] Hit [A/B] to select B Press and hold [SELECT] to
remote gang .. Crash !!!9) TT1155
Setting second remote corrupts first
