Home Forums Products Rackmount H9000 + Emote wishlist (undo+redo, copy+paste etc.) Reply To: H9000 + Emote wishlist (undo+redo, copy+paste etc.)
#155902
jbamberg
    bsfreq wrote:
    You’ve told us you’ll be adding the ability to connect between DSPs in the next release.
    What exactly does this mean? Direct patch connection only, or will it be possible to also have ”aux send”-type, level adjustable connections between algorithms running on different  DSPs?
    I really hope for the latter, as it would be so cool to be able to have midi mappable send levels inside the H9000 without having to use an external mixer when running multiple instruments through the H9000 simultaneously. (Of course this would require the possibility to route multiple algorithm ”sends” to the same algorithm input /return)
    I also hope we’ll be able to combine multiple inputs and outputs more freely soon.
    Thanks for all your work! I hope you’ll be able to release some updates soon. We’re all here patiently waiting. 😉
    It turned out to be more difficult than we expected to make the UI work properly for inter-DSP connections.  We're still planning to do this though.  We were initially just going to allow direct 1-1 patch connections, but subsequently had the idea to add mixing and gain control within the H9000 main audio router, enabling more complex setups.  We'll get there – thanks for being patient.
